Aegis1 Posted December 18, 2008 Share Posted December 18, 2008 I drew a VP in my layout this morning and I went to change the scale for it but the only scaling options that I have are scale to fit, custom, and 1:1. I have AutoCAD 2009, windows xp. When I go to change the scale I select the Viewport and I use the quick properties, I also tried using the normal properties and the same thing. The annotation scale is 1:1. Anyone help would be great. Thanks Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 18, 2008 Share Posted December 18, 2008 Type UNITS and check to make sure that your drawing units are set up properly. Then check on the |Scale| tab. Is that empty as well? If it is, click the [Add] button to specify your scales. I'd also check out your templates, once you set them any new drawings should be fine. Quote Link to comment Share on other sites More sharing options...
Aegis1 Posted December 18, 2008 Author Share Posted December 18, 2008 Got it! I typed in scalelistedit in the command line and added the scale I needed. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
