Please Enter No More Than 128 Characters
Anybody ever have this message show up in a dialog box inside of AutoCAD?
It shows up when I try to edit the drawing setup through the project menu. I have to click the OK button 7 times before it will display the drawing setup dialog box. However, when the box finally shows up, I am unable to edit anything.
Anyone had this problem? It is really getting to be annoying. I am restricted in my drawings. I cannot change the scale of the drawings, or any of the other options that I used to change in the drawing setup menu.
When it first started I was able to change a file path that exceeded 128 chars, but it messed up a bunch of other settings, so I defaulted back.
I am in an office with a number of people that are running the same version of AutoCAD, on the same build of computers.
Thanks in advance for any advice. :?
Nobody has seen this?
:( I am sorry to say I have not encountered that problem.
  • 3 weeks later...
Bump.....anyone?
This is becoming a bad problem.
It's a limitation of the application.
You'll have to move your project files up closer to the root file.
This must be a network deployment, right?
What is the exact path? Do any of the folders have appended names such as .WINNT?
