Problem with AutoCAD VBA creating named range in ecxell work bork
I want tho create a named rangein excel from autocad.
I can not call the workbook.names.add method and pass the arguments.
This works from within Excel VBA but not from within AutoCad VBA.
I am working with AutoCAD 2009 and excel 2007.
Following VBA code doesn't work in AutoCAD VBA:
Sub Test()
Dim Excel As Excel.Application
 Dim ExcelSheet As Object
 Dim ExcelWorkbook As Object
 Dim RowNum As Integer
 Dim Header As Boolean
 Dim elem As AcadEntity
 Dim Array1 As Variant
 Dim Count As Integer
 ' Launch Excel.
 Set Excel = New Excel.Application
 ' Create a new workbook and find the active sheet.
 Set ExcelWorkbook = Excel.Workbooks.Add
 Set ExcelSheet = Excel.ActiveSheet
'This line causes the error
ExcelWorkbook.Names.Add Name:="myName", RefersToR1C1:= "=Sheet1!R1C1:R10C10"
ExcelWorkbook.SaveAs "Attribute.xls"
 Excel.Application.Quit
End Sub
Can someone help me ?
Thank You very much,
Peter Van der Velden
Deinze
Belgium
Edited by SLW210
Code Tags!
  • 3 months later...
hope still helps
your code works with Autocad 2014 and Excel 2013. only noticed it starts a hidden Excel session, so I had to add
Excel.Visible=true
statement
maybe your problem could derive from your default new workbook sheets management options, since:
- you first set "ExcelSheet" as the Active Sheet of the new Excel application
- but when creating the named range you reference it to "Sheet1" sheet
so maybe the new Workbook you created doesn't have any sheet called "Sheet1" (or any sheet at all!)
I'd suggest to add code for:
- checking for the existence of the sheet you need to point to
- and then refer to it
