steven-g Posted May 14, 2015 Posted May 14, 2015 You're welcome, I don't know how you use you're macro's, personally I like to have them in various toolpallete tabs, so you can get at them quickly, and I have a few of this sort of macro setup just for toggling variables on/off. Quote
vernonlee Posted May 14, 2015 Author Posted May 14, 2015 You're welcome, I don't know how you use you're macro's, personally I like to have them in various toolpallete tabs, so you can get at them quickly, and I have a few of this sort of macro setup just for toggling variables on/off. I do them by icon. I can apply this code to other variables as well? ^C^C^C$M=$(if,$(=,$(getvar,[b]fillmode),1[/b]),setvar;[b]fillmode;0[/b],setvar;[b]fillmode;1[/b]);rea; I just replace other variables with the one highlighted in Bold right? Quote
steven-g Posted May 14, 2015 Posted May 14, 2015 I would hesitate to say yes for everything, but in theory yes, all it does is check if the existing value =1, and if it does it changes it to =0, and if it doesn't =1 then it sets it to=1 (but it will change any value that is not =1), so it's best suited to variables that only have those two options. Quote
vernonlee Posted May 14, 2015 Author Posted May 14, 2015 I would hesitate to say yes for everything, but in theory yes, all it does is check if the existing value =1, and if it does it changes it to =0, and if it doesn't =1 then it sets it to=1 (but it will change any value that is not =1), so it's best suited to variables that only have those two options. Understood. That should be sufficient for my level. Quote
vernonlee Posted May 14, 2015 Author Posted May 14, 2015 Thanks guys for everything. I can consider this as solved. Quote
tombu Posted May 14, 2015 Posted May 14, 2015 (edited) Is there a system variable to control the display of polyline widths? Due to my work, there is a bunch of existing polylines with different widths that i need to adjust (but not the width) so I need to toggle them on/off visually. If no, is there is a roundabout way? Thanks I use width for pavement striping and lineweights for everything else. Button on the status bar toggles the lineweight display off/on. Edited May 14, 2015 by tombu added display Quote
marmo Posted May 14, 2015 Posted May 14, 2015 I use width for pavement striping and lineweights for everything else. Button on the status bar toggles the lineweight display off/on. This command don't works with pline with width > 0. Quote
marmo Posted May 14, 2015 Posted May 14, 2015 +1 Marmo - I like that thinking outside of the box,BlackBox - sometimes I wish I had access to LISP the possibilities seem endless, and to be honest this is one of the first pieces of code that I can actually understand, it looks logical to someone who has never looked into the syntax of the language. vernonlee - I have no choice but to use scripts and macro's, here is a slight adaptation that will just toggle the fillmode on/off ^C^C^C$M=$(if,$(=,$(getvar,fillmode),1),setvar;fillmode;0,setvar;fillmode;1);rea; Thanks Steven! Quote
