Control the xref layers based on selected object
Hi
Using acad 10.
when you want to hide a layer in the xref, ull use Freeze and select the object. in the same way i want to changh the color of the layer in the xref.
is that built-in acad function?
Thanks
S
You can do that through your layer manager.
(vl-load-com)
(defun c:CLCN () (c:ChangeLayerColorNested))
(defun c:ChangeLayerColorNested (/ *error* entity layer layers color acDoc oLayers)
 (princ "\rCHANGELAYERCOLORNESTED ")
 (defun *error* (msg)
   (if acDoc
       (vla-endundomark acDoc)
       (vla-regen acDoc acAllViewports)
   (cond ((not msg))                                                   ; Normal exit
         ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
         ((princ (strcat " ** Error: " msg " ** ")))
   )        ; Fatal error, display it
 (while
   (/= nil
       (setq entity
              (nentsel
                "\nSelect nested entity to change layer color: "
    (if
      (not
        (vl-position
          (setq layer
                 (if
                   (= "0" (setq layer (cdr (assoc 8 (entget (car entity))))))
                    (cdr (assoc 8 (entget (car (last entity)))))
                    layer
          layers
       (print (reverse (setq layers (cons layer layers))))
 (if
   (and
     layers
     (setq color
            (if (= 1 (length layers))
              (cdr (assoc 62 (tblsearch "layer" (car layers))))
              1
     (princ "\nSelect replacement layer color: ")
     (setq color (acad_colordlg color nil))
      (vla-startundomark
        (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
      (setq oLayers (vla-get-layers acDoc))
      (foreach layer layers
        (vla-put-color (vla-item oLayers layer) color)
 (*error* nil)
(vl-load-com)
   (if acDoc
 (while
   (/= nil
       (setq entity
              (nentsel
    (if
      (not
        (vl-position
          (setq layer
                 (if
                    layer
          layers
 (if
   (and
     layers
     (setq color
              1
      (vla-startundomark
 (*error* nil)
Thanks Blackbox 8)
Thanks Blackbox 8)
You're welcome, samifox; I'm happy to help. :)
