Shoey Posted May 19, 2015 Share Posted May 19, 2015 Hi all, I have a problem with an AutoCAD table. Using AutoCAD Civil 3D 2013 (AutoCAD profile). Table is linked to a dxe file. When table is inserted using current table style, i make some tweaks in some borders and fills. I then break the table to fit on the sheet. Looks good on sheet in paper space and plot previews fine. However, when i plot either to PDF or printer, the first table break appearance is fine but the second table break adjusts to the current table style settings and loses the modifications on the output. As mentioned, All's well when i save and re-enter the dwg. Its just when plotting that it does not cooperate! Any one else had this issue? Regards Quote Link to comment Share on other sites More sharing options...
