SebastianTheCrab
Autolisp function yields different results when ran on-screen vs. off-screen.
SebastianTheCrab
The source of the problem is a helper function drawportsegment:
(defun drawportsegment (loc portspacing / portw porth test)
(setq
	portw 2.0
	porth 1.0)
(command "rectangle"
	(list (- (car loc) (/ portw 2.0)) (cadr loc) 0.0)
	(list (+ (car loc) (/ portw 2.0)) (- (cadr loc) porth) 0.0))
(command "line"
	(list (car loc) (- (cadr loc) porth) 0.0)
	(list (car loc) (- (cadr loc) portspacing) 0.0)
As it is relevant information, the test function I wrote to interface with drawportsegment is testdps:
(defun c:testdps (/ loc portspacing)
(setq
	loc (getpoint "\nwhere?")
	portspacing 2.0)
(drawportsegment loc portspacing))
Here is a direct comparison of this function running on-screen vs. off-screen:
I do not understand why figure A is generated, as I would think from looking at the code that figure B would always be generated.
All help is appreciated!
Share this post
Link to post
Commandobill
(setvar 'osmode 0)
Share this post
Link to post
Commandobill
To explain: When the object is on the screen your osnaps are active, this if you get the current osmode and set it to variable, then change the osmode to 0 while your program is running, then it will not snap to an object, then you turn it back to what it was.
Share this post
Link to post
SebastianTheCrab
It worked - thank you!
Share this post
Link to post
Commandobill
No problem :thumbsup:
Share this post
Link to post
BIGAL
A suggestion the changing of osmode is pretty common in lots of situations.
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
your code
(setvar 'osmode oldsnap)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
