Hi,
I have a trivial question that i seems unable to solve. I use AutoCAD 2008 full version on my XP Pro machine. The problem i'm having is i can not use the mouse to pan a drawing. I do not know what causes it. I have changed the mouse over with other mouse but still to no avail. However, if i typed in "pan" into the command line, then it works. It stops working after pressing "Esc" button which gets out of the command. Is it to do with settings i need to tweak in the software or is it my computer?
Any helps would be greatly appreciated.
Thank you in advance
Thank you for your reply, Cad64.
It works now. It's the mouse that's playing up.
Thanks again
