tool bars>dimension> arc length :P
You do have an awesome sense of humor :shock:. You should write a book :wink:
.. ill give you my first copy...:shifty:
Set the osnapz command to 1 and draw a bunch of arcs following contours. Then do as above.
command dimarc for arc length and dimradius for radius of arc
  • 3 months later...
Now there isnt a way, like in Microstation, to measure along a line is there? If not does anyone have a lisp with such a function?
