spittle Posted December 22, 2008 Posted December 22, 2008 I've set up a title sheet, and I've linked some of the text to the Properties of the drawing so I can edit all of the all of the fields in the Properties (FILE>PROPERTIES). The only thing is, I don't want to use the same properties for every Sheet eg, I want the drawing numbers to be different. Is there a way I can sort this out? I want to ideally be able to change all of the fields via some kind of interface rather than manually having to edit sheet format and then change the text. Quote
cedar Posted December 26, 2008 Posted December 26, 2008 While in a drawing… RMB on the “Sheet Format”. Click “Edit Title Block” (I think it’s there in 2008?) That’s the tool to create editable text in the title block. See Help. After you have some editable text you can RMB on the title and click “Enter Title Block Data” and the editable text is highlighted. Quote
