Help with Polyline Lisp (Export All Lengths to Table)
gordon_Gjs
Hello, I am searching for a lisp that can export the lengths of all selected polylines and export them to either Excel or an AutoCad table.
I have found and tested around 20 lisps but so far cannot find the right one.
There were only 2 that look promising, maybe they could be modified?
One was by Lee Mac and the other Jimmy Bergmark. I can post the 2 Lisp if needed.
The lisp would need to have you select multiple polylines and give the total lengths of each polyline in the order that they were selected in. Then the data would either appear on an AutoCad table or Excel.
Thanks for any help that can be provided.
The lengths of each individual polyline or the total length?
The lengths of each individual polyline.
Total is really not needed or can be added at the end of the table or excel if it is not to much trouble.
Try this program to export LWpolylines to Excel file with format csv.
(defun c:Test (/ s f o)
 ;; Tharwat 26. 08. 2015 ;
 (princ "\nSelect LWpolylines to export to Excel file :")
 (if (and (setq s (ssget '((0 . "LWPOLYLINE"))))
          (setq f (getfiled "Specify File Name" (getvar 'DWGPREFIX) "csv" 1))
          (setq o (open f "w"))
     ((lambda (r / e)
        (while (setq e (ssname s (setq r (1+ r))))
          (write-line (rtos (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) 2 4) o)
       -1)
     (close o)
Looks good so far. I do have a few tweaks if possible.
Is there a way to have the values show up in feet only?
Is there a also a way to have it load up excel without having to save location first and then open?
Add the complete path of the Excel file and be aware that each time you run the program , the new data would replace the old once .
          (setq f [color="red"]"C:\\New Folder\\Example.csv"[/color]) ;; [color="silver"]path of Excel path[/color]
     ((lambda (r / e)
         (write-line (rtos (cvunit (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) "mm" "feet") 2 4) o)
       -1)
     (close o)
Edited by Tharwat
I could only get it to save to my thumb drive. It would not save to the local drive C:. Any idea of why this would be? Maybe trust issues? Does it have to save at all or can it just open excel?
Also, could you have the values show up in feet?
Thanks for all your help!
Yeah , it might be a matte of security issue , anyway right click on the folder that you wan to safe the excel file in , then go to properties then from the show up dialog go to security tab and edit the group / user name to have a full access.
If the program did not change the value to feet format from the latest posted program , and replace the number 3 to 4 and try again.
It is still not showing up in feet. Do you have any other ideas to get it to feet?
     ((lambda (r / e)
         (write-line (rtos (cvunit (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) "inch" "feet") 2 4) o)
       -1)
     (close o)
Awww, ok. That is much better, I had to change the "mm" to "inch" and that cleared it up.
One more thing, is there a way to have it open the excel file automatically without having it save anywhere? Or possibly export the data into an autocad table instead of excel?
Here is a table version, works for me as metric may need mods for inches re row sizes etc. Will only work in modelspace see curspace.
Tharwat stuffed up lambda please help any other suggestions welcome.
(defun c:Test (/ s x y doc objtable numrows rowheight pt1 colwidth curspace)
;; mods by BIGAL 29.08.2015 now as table
(vl-load-com)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq curspace (vla-get-modelspace doc))
(setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table:  ")))
(princ "\nSelect LWpolylines to export to a Table :")
(if (/= s nil)
 ; now do table
   (setq numrows (+ 2 (sslength s)))
   (setq numcolumns 2)
   (setq rowheight 7)
   (setq colwidth 25)
   (setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth))
   (vla-settext objtable 0 0 "Pline lengths")
   (vla-setcolumnwidth objtable 0 10)
   (vla-setcolumnwidth objtable 1 25)
   (vla-settext objtable 1 0 "Pline")
   (vla-settext objtable 1 1 "Length")
   (vla-SetTextHeight Objtable (+ acDataRow acHeaderRow acTitleRow) 2.5)
   (vla-SetAlignment Objtable acDataRow acMiddleCenter)
   (setq x 1)
   (SETQ Y 2)
   (setq r -1)
   ;((lambda (r / e)
        (while (setq e (vlax-ename->vla-object(ssname s (setq r (1+ r)))))
        (vla-settext objtable Y 0 (rtos x 2 0))
        (vla-settext objtable Y 1 (rtos (cvunit (vla-get-length e) "inch" "feet") 2 4))
        (setq x (1+ x ))
        (setq y (1+ Y ))
 ); while
    ; )) ;lambda
     )   ;progn
   (alert "You have not picked any plines run again")
   )     ; if
) ; defun
(c:test)
Thanks, it worked great! Thanks Tharwat and BIGAL.
BIGAL, I was testing the lisp and came across 3 issues. If you have time can you check them out below?
1.) When the lisp loads it wants to run immediately. Is there a way to have it only run when you enter the command for it?
2.) Is there a way to change the format of the table to have zero precision and show the length in feet. Example = 42'
3.) Is there a way to edit the text font and size the table uses?
  • 2 years later...
Hi, i have the following code
(vl-load-com)
(if (/= s nil)
; now do table
(setq numcolumns 2)
(setq rowheight 7)
(setq colwidth 25)
(setq x 1)
(SETQ Y 2)
(setq r -1)
;((lambda (r / e)
(setq x (1+ x ))
(setq y (1+ Y ))
); while
; )) ;lambda
) ;progn
) ; if
) ; defun
(c:test)
This code is used to extract the polyline length in autocad table.
I want to additionally add layers and polyline length in meter.
How can i add that please give some ideas...
Edited by SLW210
Added Code Tags
Not to hard look for matching lines in code above in most cases its add to the number an extra 1.
(setq numcolumns 3)
(vla-setcolumnwidth objtable 2 25)
(vla-settext objtable 1 2 "Layer")
(vla-settext objtable Y 1 (rtos (vla-get-length e) 2 3))
(vla-settext objtable Y 2 (vla-get-layer e) )
hi welcome, friendly msg , the code should be included in code tags
before
[NOPARSE]
your code here
[/NOPARSE]
after
your code here
