andar424 Posted September 4, 2015 Share Posted September 4, 2015 Hey guys, my co-worker has some STP files that open up just fine, but once you place them into his "main" assembly, they will not show up! You can see them in the browser tree, but all you can see are a couple sketches that are in the stp files. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
Lazer Posted September 4, 2015 Share Posted September 4, 2015 Sounds like you opened up .wire file as they will often import as sketches unless you set up the import settings, as they open fine but only have an issue in an assembly is strange, can you post the stp file here for me to investigate? Quote Link to comment Share on other sites More sharing options...
