hosyn Posted September 20, 2015 Share Posted September 20, 2015 I select object then ctrl-c don't operate and looking for object again ,whats the problem??? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 20, 2015 Share Posted September 20, 2015 Change your PICKFIRST variable to 1. Quote Link to comment Share on other sites More sharing options...
hosyn Posted September 20, 2015 Author Share Posted September 20, 2015 I tried but it isn't ok still Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 20, 2015 Share Posted September 20, 2015 So PICKFIRST is set to 1, you select an object, you hit Ctrl+C and then you hit Ctrl+V but nothing happens? Does this happen in all drawings or just one? Have you tried running an Audit on your drawing to check for errors? Have you tried closing Autocad and restarting it? Quote Link to comment Share on other sites More sharing options...
hosyn Posted September 20, 2015 Author Share Posted September 20, 2015 yes I tried in word and excell and .. ok but in cad have problem ,,,I cheked the variable to 1 and its ok for any command except ctrl-c Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 20, 2015 Share Posted September 20, 2015 What about my other questions? 1. Does this happen in all drawings or just one? 2. Have you tried running an Audit on your drawing to check for errors? 3. Have you tried closing Autocad and restarting it? It might also be helpful to know what it is that you are trying to copy and paste, and, are you trying to copy and paste from one location to another inside this one drawing, or, are you trying to copy from one drawing and paste into another? The more information you provide, the better your chances of getting the problem solved. I have to step out for a while, but hopefully someone else will be along to pick up where I left off. Good luck. Quote Link to comment Share on other sites More sharing options...
hosyn Posted September 20, 2015 Author Share Posted September 20, 2015 I tried tree suggestion check in and still not ok can it coused by virus? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 21, 2015 Share Posted September 21, 2015 Why would you think you have a virus just because copy/paste isn't working in Autocad? Take a look here and try all the suggested solutions: http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Copy-and-paste-in-AutoCAD-hangs-for-a-long-time-or-fails-to-work.html Quote Link to comment Share on other sites More sharing options...
mrzer0123 Posted September 23, 2015 Share Posted September 23, 2015 I see a lot of errors ago Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 23, 2015 Share Posted September 23, 2015 I see a lot of errors ago With or without the aid of a crystal ball? Just curious. Quote Link to comment Share on other sites More sharing options...
patguy19 Posted February 20, 2016 Share Posted February 20, 2016 THIS worked for me, THANK YOU ! (Change your PICKFIRST variable to 1.) Quote Link to comment Share on other sites More sharing options...
guran Posted February 20, 2016 Share Posted February 20, 2016 I think you find all your Pasted copies at WCS 0.0. Quote Link to comment Share on other sites More sharing options...
yasir Posted September 6, 2019 Share Posted September 6, 2019 paste not working Me too pickfirst 1 not change anything I copy drawing in a windows, and paste it at other windows result always different freak Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 6, 2019 Share Posted September 6, 2019 9 hours ago, yasir said: I copy drawing in a windows, and paste it at other windows result always different When you say "Window" I assume you mean Viewport? What do you mean by "result always different"? What happens when you paste into the viewport? By your description, it sounds like copy & paste is working, it's just not working the way you want it to. So what's different about the viewports you're copying from and pasting into? Are all layers turned on? If not, what layer do you have set current? Is it frozen in the viewport? What are you copying? Is it a block or a collection of entities? Are you copying and pasting within a drawing or are you copying from one drawing and pasting into another drawing? Have you run an AUDIT on your drawing, or drawings, to fix any errors? The more information you provide, the better your chances of getting an answer that solves your problem. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 7, 2019 Share Posted September 7, 2019 Pick object press right button mouse and you have 2 options copy or copy with a base point a little more reliable. Quote Link to comment Share on other sites More sharing options...
Tomasz Drgas Posted November 26, 2019 Share Posted November 26, 2019 I Have sometimes this isuue with some drawings.. usually saving in dxf format, opening it and copying from there (or after saving again in dwg) was helping.. Once I had problem when that was not enough. It was an export to cad from some asian structural program.. when trying to open after saving to dxf it was crushing cad. What helped was: first opening the drawing with RECOVER command which fixed 4 errors, then saving it do dxf, then opening and saving back to dwg (cos I don't want to open it from dxf every next time),.. and was working.. Quote Link to comment Share on other sites More sharing options...
Ville Posted June 9 Share Posted June 9 Hello I am having the same issue. CTRL+C works fine in windows everywhere. In autocad it works also, but it works as if pickfirst command was set to 0 when using CTRL+C. So I am having pickfirst problem only with CTRL+C command. When selecting all that I wan't to select and pressing CTRL+C, it deselects all selected objects and it prompts that I should select objects. Please help me someone :) Quote Link to comment Share on other sites More sharing options...
tombu Posted June 14 Share Posted June 14 For 2016 and newer versions of AutoCAD set PICKADD (System Variable) to Initial value of 2, and PICKFIRST (System Variable) to Initial value of 1. Don't have it open to test but I've always thought it worked the same way as anywhere else in Windows, we've always had to pick first to use Ctrl+C. Quote Link to comment Share on other sites More sharing options...
