im trying to figure out what is the the name of the autocad term that describes the letter or combination of letters that are needed to type in a command?
Please don't post the same question in two different threads, it can make things quite confusing.
For instance "L" for line or "PL" for polyline are "Shortcut keys". The commands will autofill in.
One or more Shortcut Keys will cause the command to autofill in the command line.
But you have to know the shortcut keys, so turn on Show Tool Tips, and turn on Show Shortcut Keys in Tool Tips, by going into Options >> Display tab and/or use the F1 key help file to look up the commands. You can also open up the CUI editor and navigate around to see what they are.
