Ok, I'm probbly just doing something very wrong..
but I can't get lineweights to work properly ( I think )
I'm trying to make a thicker lineweight for outerwalls of a building, but no matter what I set it at, on the model or layout pages, it's always the same thickness in the drawing.
setting it from default to 2.00mm trying to get the visual thickness.
any suggestions?
thanks
hah yeah.. found it, the glory of "search"...... should have done that in the first place.
yo should post your solution, even if u found it for your self. it may help someone else in similar situation.
At the bottom of the screen near the snap etc menu ( bottom left corner ) there is a lineweight toggle.. on and off.
I clicked it and there it was... visible.
Wouldist a Poly-Line be better, perhaps?
not really... its lineweight not a polyline.
I'm trying to break myself of the habit of assigning lineweights to polylines and trying to assign lineweights at plot time via the layer properties manager. Probably more efficient.
