delkovebay Posted October 12, 2015 Share Posted October 12, 2015 Hi to all. My trouble is that I want to make invisible some object (e.g spline), but with opportunity to click on it by mouse to change it and etc. My solution is like this (vla-put-entitytransparency obj LEVEL) But max value of "LEVEL" is only 90.. How can I get around it? Or there are another ways? Thanks. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted October 12, 2015 Share Posted October 12, 2015 Hi to all.I want to make invisible some object ...but with opportunity to click on it by mouse If you make an object invisible, how will you click on it later? Object do have a visible property. Change that to false to make them invisible. But the end user won't be able to select them afterwards. You'll have to restore the visibility some other way. The 90 limitation you see is simply the limitation of that property. No way around. Oops, nevermind. For other readers, see: http://www.theswamp.org/index.php?topic=50238.0 Quote Link to comment Share on other sites More sharing options...
