Multi-select Pline convert to revcloud?
ttray33y
I have a selection set already and wanted to convert those polyline to revcloud however the acad revcloud function only allow last or point.
it this doable guyz? I tried this in microstation and it did convert those pline to revcloud at once. :D
Sure you can.
(defun c:demo ()(if (setq ss (ssget))(repeat (sslength ss)(command-s "_Revcloud" "_Object" (ssname ss 0) "_n")(ssdel (ssname ss 0) ss))))
But all preparations should be done beforehand like arc length etc...
Try something like this:
(defun c:mrc ( / c i s )
   (if (setq s (ssget "_:L" '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE"))))
           (setq c (getvar 'cmdecho))
           (setvar 'cmdecho 0)
           (repeat (setq i (sslength s))
               (command "_.revcloud" "_o" (ssname s (setq i (1- i))) "")
           (setvar 'cmdecho c)
EDIT: pBe beat me to it :)
I know you did but I cannot find it. I was having trouble with the arcs and you posted something about rev clouds. I don't think I was involved in the thread (just being a creeper). I'll find it
Maybe this?
