I am using the following code to open a dwg file and inserting several dwgs from vb6
The following is the vb codeI am using
Str = "C:\Program files\autocad LT 2006\aclt.exe" & " C:\1.dwg" & " /b " &"C:\script.scr"
Shell Str, vbNormalFocus
The script file contains code to insert several drawings
After inserting the drawings I will minimize the 1.dwg file screen.
When I execute the same command once again I want to active 1.dwg sreen once again. But now it is opening the file once again in read only mode
Can any one tell me vb code on how to activate already opened file and inserting new set of drawings instead of opening into a new screen in read only mode
Sham.S
Edited by: shamsam1 on Dec 24, 2008 5:10 PM
