Marco1979 Posted October 29, 2015 Posted October 29, 2015 Is there a way to simply batch-plot all my sheets with different sizes all at once (hopefully creating seperate files). In acad this was very nice using sheetsets. only workaround i found is this: http://revit-nightmares.blogspot.be/2009/10/quick-printing-of-all-sheets-in-project.html But exporting, opening, save as pdf.....isnt there a nicer way?? thanx. Quote
tzframpton Posted October 29, 2015 Posted October 29, 2015 Oh yeah, certainly. It's very easy. First make sure you have a good PDF Plot Driver installed. The absolute best one for Revit, hands down, is PDFCreator: http://www.pdfforge.org/pdfcreator Then, follow the steps below. Now you won't be able to do multiple sizes at once. Then again I've never tried digging into this either. #5 is where you choose it to be separate files, or one massive file. Use the setup in PDFCreator to suppress the dialog box that pops up for each sheet. When you have multiple PDF's being made, this gets really annoying and fast. This way it'll just default to whatever directory and bam, all done. Use a utility like Bulk Rename Utility to rename the files in a batch process (removing prefixes, etc). Hope this helps. -TZ Quote
Marco1979 Posted November 2, 2015 Author Posted November 2, 2015 Thanx, but thats not exactly what im looking for. Like you said, iit would be so much more efficient to send say 40 drawings at once to f.i. a PDF plotter, without having to worry about anything. In the link they use "choose paer source by paper size"...that would by such a great thing to have. Quote
tzframpton Posted November 2, 2015 Posted November 2, 2015 You do not have this option in Revit that I know of, so the workaround is all you have unfortunately. Quote
Marco1979 Posted November 3, 2015 Author Posted November 3, 2015 That's a bummer...thanx anyway. Quote
