broncos15 Posted November 5, 2015 Posted November 5, 2015 I am trying to make a macro that will expedite having to use point filters. My main goal is for when I have a feature line selected and I want to move a PI using the grips, but I want the elevation to stay the same. It is meant to just be a shortcut instead of having to use the .xy point filter and then having to say the elevation at the end. I put my code in the object snap cursor menu so that when the user right clicks they can choose my option instead of having to choosing the point filters one. I wrote the following code: .XY;/;@; Unfortunately the code isn't working correctly and I get the following when I run it I still have to enter in the elevation (it doesn't go immediately) to the @ symbol I put in. I know I am making a stupid mistake, but I can't figure out what it is. I also tried: .XY;non;@; but it doesn't work either. Quote
SEANT Posted November 5, 2015 Posted November 5, 2015 Conceivably, a 'feature line' is akin to a 3dPolyline. I say that because a standard Polyline has vertex elevation maintenance built right in. If a 3dPoly like entity requires vertex manipulation whilst maintaining Z elevation I'd say place the "OnlyXY" macro (in post #10 of this thread) into Shortcut Menu - Grip Cursor Menu. Quote
broncos15 Posted November 5, 2015 Author Posted November 5, 2015 Conceivably, a 'feature line' is akin to a 3dPolyline. I say that because a standard Polyline has vertex elevation maintenance built right in. If a 3dPoly like entity requires vertex manipulation whilst maintaining Z elevation I'd say place the "OnlyXY" macro (in post #10 of this thread) into Shortcut Menu - Grip Cursor Menu. Thank you SeanT for the help! So I added the macro listed into my Shortcut Menu - Grip Cursor Menu but it still isn't working correctly. It shows the feature line moving to the new location but then nothing happens and I get the following from AutoCAD ** STRETCH ** Specify stretch point or [base point/Copy/Undo/eXit]: .xy of @ (need Z): Command: *Cancel* What do you think could be the issue? Quote
SEANT Posted November 6, 2015 Posted November 6, 2015 The Command Line output shown above leads me to believe that the macro was not copied correctly. Based on the original post, I think the vertex needs to move only in the XY direction so you should use: .z;@; For a standard 3dPoly, this is the resultant operation: https://screencast.autodesk.com/main/details/cb01014b-89f1-44ca-b0d9-521571f01084 Quote
broncos15 Posted November 6, 2015 Author Posted November 6, 2015 The Command Line output shown above leads me to believe that the macro was not copied correctly. Based on the original post, I think the vertex needs to move only in the XY direction so you should use: .z;@; For a standard 3dPoly, this is the resultant operation: https://screencast.autodesk.com/main/details/cb01014b-89f1-44ca-b0d9-521571f01084[/Quote] You are correct, I copied the wrong one. The correct macro works perfectly, so thank you very much! Quote
