ReMark Posted November 19, 2015 Posted November 19, 2015 From the command line it would be OSOPTIONS. Set to a value of 1 and it will ignore hatch objects. This can also be accessed via Options > Drafting tab > Object Snap Options. I don't think resetting this variable will make any difference in your drawing. Quote
byk3bep Posted November 19, 2015 Author Posted November 19, 2015 It's the correct value, and the check box is ticked... Quote
ReMark Posted November 19, 2015 Posted November 19, 2015 Maybe it is the sheer amount of hatching used and the fact that some of the patterns used (ex. - honey & sand) are so dense? Quote
byk3bep Posted November 19, 2015 Author Posted November 19, 2015 Removed the hatching, there was improvement, not drastic, but detectable. Removed all the text, better. Removed the dimensions => feels workable I will copy the drawings to another file one by one, and remove all the junk. Who knows what could be the prob... I'll get back to you tomorrow with the results... Thx for the help guys Quote
ReMark Posted November 19, 2015 Posted November 19, 2015 I'm pretty sure someone alluded to this previously when there was a mention of using the Flatten command. Do this. Open the original drawing. Instead of a Top view look at the drawing from a Front view and notice there are a number of objects with a "Z" greater than "0". For example, if you do a LIST on one of the elevations depicted in the image below you'll see the value of Z corresponds to the elevation (in millimeters). Maybe this is what is causing the lag. Now do this. Freeze all of the following layers then try editing your drawing. Kote-visinske T_ZNACI Tacke Ograde Struja Kanalizacija Stepenico Temelj Asfatni Put I'd also freeze layer 251 which is the layer the image is on. Quote
byk3bep Posted November 19, 2015 Author Posted November 19, 2015 Ok, did the above mentioned, no change. Sent it to my brother to delete the imported geo. site plan and split it in to 2 pieces. I just copy/pasted it without inspecting it first. Because it's faster... Right? Lesson learned (I hope). Now that it is manageable I could use a tip on how to get it right this time. What do you suggest? I have to place the building on the site plan. Thx for your time Quote
Dana W Posted November 20, 2015 Posted November 20, 2015 Has anyone else zoomed extents in this drawing? Did I miss you guys finding these? There are hundreds, maybe thousands of tiny little blocks all over the place in outer space, I'm talking miles from 0,0. each one is 4 short lines. I got rid of them and it started being manipulatable. My computer isn't any stronger than yours. Quote
ReMark Posted November 20, 2015 Posted November 20, 2015 Were any of these objects on the layers I mentioned previously? Quote
Dana W Posted November 20, 2015 Posted November 20, 2015 Were any of these objects on the layers I mentioned previously?I didn't check that. Quote
ReMark Posted November 20, 2015 Posted November 20, 2015 Now that it is manageable I could use a tip on how to get it right this time. What do you suggest? I have to place the building on the site plan. I think a project like this would be well handled using xrefs but that is just my opinion. Quote
byk3bep Posted November 20, 2015 Author Posted November 20, 2015 Thx for you opinion, it's valuable Quote
