broncos15
Create selection set for previous objects
broncos15
I am curious on how to create a selection set of polylines that were just converted into feature lines. After the _AeccCreateFeatureLines command is run, I am not able to use previous command for the feature lines just created. The reason I am wondering is because I am trying to create a reactor that runs a lisp on these just created feature lines.
Share this post
Link to post
broncos15
I should also add this caveat.I have tried using the last command, but the issue is that it just selects the last created object. For example, if 10 feature lines are created at once, it will only select the last one, not all 10. My only thought is to create another reactor that would run before the objects are converted to feature lines. It would create a selection set of the objects being created and then "feed" the selection set to my reactor that will run after the command is completed. Is there an easier way to do this?
Share this post
Link to post
tombu
Not that I know of I've used Irné Barnard's selresult.lsp http://forums.augi.com/showthread.php?81175-select-result-lisp-modification#5 to do that since 2008. It's loaded in my acaddoc.lsp as it must be preloaded.
Share this post
Link to post
Lee Mac
Retrieve the last entity in the drawing database using the following function prior to running the _AeccCreateFeatureLines command:
;; entlast  -  Lee Mac
;; A wrapper for the entlast function to return the last subentity in the database
(defun LM:entlast ( / ent tmp )
   (setq ent (entlast))
   (while (setq tmp (entnext ent)) (setq ent tmp))
   ent
And then iterate over all entities added to the drawing database following the command using the entnext function supplied with the previous last entity, i.e.:
(setq ent (LM:entlast))
(command "_AeccCreateFeatureLines")
(while (< 0 (getvar 'cmdactive)) (command "\\"))
(while (setq ent  (entnext ent)) (setq lst (cons ent lst)))
Share this post
Link to post
broncos15
   ent
Thanks Lee! Just to double check that I understand correctly, I would want to use your entlast function with the :vlr-commandWillStart reactor, then use your second code with the :vlr-commandEnded reactor?
Share this post
Link to post
Lee Mac
If you necessarily wish to use a reactor, then yes - retrieve the last entity within the callback function for the :vlr-commandwillstart event, and process the created entities within the callback function for the :vlr-commandended event.
Alternatively, just define a wrapper for the _AeccCreateFeatureLines command which would evaluate the command in addition to performing the operations you require.
Lee
Share this post
Link to post
broncos15
Lee
Lee, thank you for the help! I wanted to allow the user to be able to disable my version, which is why I was planning on going the reactor route (plus my company typically doesn't like to redefine commands). I know just redefining it would be much easier though.
Share this post
Link to post
Lee Mac
You're welcome.
I'm not suggesting that you redefine the standard command, but rather define a custom command which the user may invoke to start the standard command whilst performing your operations.
Share this post
Link to post
broncos15
Oh, I misunderstood what you were initially saying. My company has a lot of other lisp routines that make use of the CreateFeatureLines command, which is why I don't think making another command would work (then my new one would either have to be placed in all the other lisp routines and .net applications, or it would only work if invoked from the command line). Overall I think your thought is a much more efficient way to code it, but unfortunately I think I will have to just make use of some reactors. Thanks again for your help, and your website has been super helpful for me as well!
Share this post
Link to post
broncos15
Lee, so I have been working on it for a while and I am getting hung up on turning the reactor on or off, and how to feed the variable to my already created lisp function. I have my lisp function "featurelinecrossing" already preloaded, but I figured that I should load it again just in case it didn't load correctly. My code is as follows:
;;;This reactor used AfraLisp reactor example as a starting point
(vl-load-com)
(vlr-command-reactor
nil '((:vlr-commandWillStart . startCommand)))
nil '((:vlr-commandEnded . endCommand)))
;;;Reactor to store information when command first starts
(defun startCommand (calling-reactor startcommandInfo /
      thecommandstart ent)
(setq thecommandstart (nth 0 startcommandInfo))
;;;Here is where the real reactor comes into play
;;;This reactor runs after the command has ended
(defun endCommand (calling-reactor endcommandInfo /
    thecommandend)
(setq thecommandend (nth 0 endcommandInfo))
(cond
 ((= thecommandend "_AeccCreateFeatureLines")
  (load "featurelinecrossing" "")
    (featurelinecrossing "PI" ent "")
   ent)
;;; Command to turn the reactor on or off
(defun c:InsertPI ( / opt)
(initget "On Off")
(setq opt (getkword "\nTurn off or on? [On/Off]: "))
(if (= opt "Off") (setq "AutoInserPI" "")
                    (setq "AutoInsertPI" opt)
Share this post
Link to post
Lee Mac
First very important question: does your featurelinecrossing function call any AutoCAD commands?
Share this post
Link to post
broncos15
Lee, no it doesn't (I know that reactors can't make use of commands). The link to the lisp is here:http://www.cadtutor.net/forum/showthread.php?94534-Automation-Error-No-Description-provided
You along with Hippe013 were able to help me get it working. It primarily just makes use of vlax functions.
Share this post
Link to post
Lee Mac
Thanks - I assume that you have rewritten the c:FeatureLineCrossing function found in that thread to remove the user input and accept three arguments?
Share this post
Link to post
broncos15
Lee, you will have to pardon my ignorance, but why can't I just give the information to the lisp routine where the user would typically, like how I would with a normal command?
Share this post
Link to post
Lee Mac
AutoLISP functions do not operate in that way - evaluating the function c:featurelinecrossing is no different to evaluating any other AutoLISP function. Since AutoLISP runs on the single GUI processor thread and does not allow multiple threads, operations must be performed in sequence; therefore, when the c:featurelinecrossing function is evaluated, the calling function must wait until the evaluation of the c:featurelinecrossing function has completed before continuing evaluation.
Share this post
Link to post
broncos15
Lee, thank you for the information, I didn't know that. I will create another featurelinecrossing lisp routine that doesn't require user input. Thanks again for the help!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
