HREAM Posted December 8, 2015 Posted December 8, 2015 I need to have 4 different sides of my model in the layout. I created 4 viewports, but when I edit one of them, all of the models are being edited. I understand why this is happening, but I don't have a clue how to resolve this. Any help? Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 When you created your four viewports did you designate one for the top, front, side views and whatever you are using for the fourth view? Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 When you created your four viewports did you designate one for the top, front, side views and whatever you are using for the fourth view? Yes, but I am talking about editing the model itself. I have to show the 3D model in seperate parts, so when I try to seperate the model in my 2nd layout viewport, it also gets seperated in other viewports and I don't want that to happen. P.S. I am sorry, I am a beginner Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 Back up a minute. Are your viewports in model space or in a paper space layout? If you are using a layout put the separate sections of your model on different layers (using different colors too) then use the viewport layer freeze feature of the layer properties manager to display only the layer you want. Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 Back up a minute. Are your viewports in model space or in a paper space layout? Paper space layout. Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 Then refer back to my previous post for one possible solution. Quote
rkent Posted December 8, 2015 Posted December 8, 2015 You are looking at the same model in each viewport, so naturally any editing done to the model will reflect in each viewport. Not sure exactly what you are after but you might try putting each part on a separate layer and if you need to show one view with the parts separate then create extra duplicate viewports, freeze all layers but one in each viewport using the VPfreeze column in the layer manager, and then arrange from there. Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 Guys this is how my model looks like: Basic stuff, I know. And this is how it should look like in the layout: Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 I can't seem to paste URL's and images in my post. Is there somewhere else I could message you guys? Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 I have a suggestion. Attach a copy of the drawing to your next post and someone here will take a look at it. If the file size exceeds limits then upload the drawing to a file sharing website like Dropbox and post a link to it here instead. Images are not all that useful to us. Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 This is the drawing itself. https://www.dropbox.com/s/vw1ws9va4hvmm0i/assignment2.dwg?dl=0 http://i.imgur.com/mmMFvqu.png and this is how it should look finalised. Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 (edited) Viewport layer freeze example. All four objects exist in each viewport but some layers have been frozen in three of the viewports. Edited December 8, 2015 by ReMark Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 This is the drawing itself.https://www.dropbox.com/s/vw1ws9va4hvmm0i/assignment2.dwg?dl=0 http://i.imgur.com/mmMFvqu.png and this is how it should look finalised. Follow rkent's advice and you should be able to create exactly what you have shown in your image. Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 Another example. All three objects exist in each viewport although only one is displayed. Quote
TheCADnoob Posted December 8, 2015 Posted December 8, 2015 I need to have 4 different sides of my model in the layout. I created 4 viewports, but when I edit one of them, all of the models are being edited. I understand why this is happening, but I don't have a clue how to resolve this. Any help? TO get it to look like your example you are going to probably have to use around 11 view ports. The Majority of the viewports will be used to create the exploded parts at the bottom left and you will use the freeze fram as everyone has indicated. You can dimension your drawing in paper space so don't try to dimension in model space. The top two view ports will be the same but you will dimension the top right in paper space. To get the image on the bottom left you will have to use section view. Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 How did you arrive at eleven viewports? Why would you need more than one viewport to create the exploded view? Quote
TheCADnoob Posted December 8, 2015 Posted December 8, 2015 How did you arrive at eleven viewports? Why would you need more than one viewport to create the exploded view? sorry, was looking at example. she would need 4 for her exploded view and then at least an additional three to complete the full layout in the example. EDIT: did you use three to create your example above? Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 I think it would take three viewports as one of them would be a duplicate. Note that the top two viewports are the same except one is dimensioned. The exploded view I'd do using duplicate geometry (if needed) and just space it all out and show it in one viewport. The sectional view would require its own viewport. Yes, I used three viewports arranged vertically for the image seen in post #15. Quote
HREAM Posted December 8, 2015 Author Posted December 8, 2015 I think it would take three viewports as one of them would be a duplicate. Note that the top two viewports are the same except one is dimensioned. The exploded view I'd do using duplicate geometry (if needed) and just space it all out and show it in one viewport. The sectional view would require its own viewport. Yes, I used three viewports arranged vertically for the image seen in post #15. Could you please send me the .dwg file of that example? Quote
