Zox Posted December 18, 2015 Share Posted December 18, 2015 (edited) I'm doing some 3d model and whenever I open the project the texture called "Beechwood-Honey" is not on the assigned surface and I have to put it on back every time. All other textures are memorized but not this one. Anyone knows what's the problem? edit: it also won't remember some other textures and also some of the same textures but on different surfaces also are not there when I re-open. Edited December 18, 2015 by Zox Quote Link to comment Share on other sites More sharing options...
Zox Posted December 19, 2015 Author Share Posted December 19, 2015 It seems to correspond to the way I put the texture on. If I put it only on one surface (by holding "ctrl" key) Autocad may not save it, but if I put texture on the whole object then it will save it for sure. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 19, 2015 Share Posted December 19, 2015 Are you up to date with all service packs? Are the textures saved in your project folder or are they located elsewhere on your computer/network? Quote Link to comment Share on other sites More sharing options...
Zox Posted December 21, 2015 Author Share Posted December 21, 2015 (edited) OK I installed service packs and problem seems to be licked. Thanks! Edited December 21, 2015 by Zox Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 21, 2015 Share Posted December 21, 2015 I just threw that out there as a wild guess. Glad to hear it solved the problem. Quote Link to comment Share on other sites More sharing options...
