anindya Posted December 19, 2015 Share Posted December 19, 2015 Respected sir I received those type of data in regular basis and it is done by linear measurement method.Now if i have to plot it in drawing then i need coordinate.How will i get that one.I know offsets are taken in perpendicular from alignment but to plot it in offset command is really a hard job to get the coordinates.If i get that in a table by just a click then it will make my job very easy.Is there any lisp or any Vba to solve that one.please help for that one.I have attached one sample drawing for understanding purpose. Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
sanju2323 Posted December 19, 2015 Share Posted December 19, 2015 It seems to me that your table format is designed incorrectly. Something like this should be. Table1.csv Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 20, 2015 Share Posted December 20, 2015 Search here for a offset routine by Hippo13 creates a table etc. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 20, 2015 Share Posted December 20, 2015 have a look at this http://www.cadtutor.net/forum/showthread.php?94801-coordinates-of-centerline-and-both-side-offsets/page1 Quote Link to comment Share on other sites More sharing options...
anindya Posted December 21, 2015 Author Share Posted December 21, 2015 I received those type of data in regular basis and it is done by linear measurement method.Now if i have to plot it in drawing then i need coordinate.How will i get that one.I know offsets are taken in perpendicular from alignment but to plot it in offset command is really a hard job to get the coordinates.If i get that in a table by just a click then it will make my job very easy.Is there any lisp or any Vba to solve that one.please help for that one.I have attached one more sample drawing for understanding purpose. HHH.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted December 21, 2015 Share Posted December 21, 2015 It does seem to be taking things a long way round to create a table of coordinates, and then use those coordinates to plot something. The most common mistake when plotting coordinates is to transpose or misread digits. I would use Measure to put blocks (consisting of straight lines) at right-angles along the alignment, and measure along those to give a required offset. Creating a table may be unnecessary. Quote Link to comment Share on other sites More sharing options...
anindya Posted December 21, 2015 Author Share Posted December 21, 2015 respected sir actually datas are taken by measurement tape and levelling instrument used by surveyors there only level & offset distance can be achieved.now if i have to plot on drawing i need coordinates.so please help me to plot. Quote Link to comment Share on other sites More sharing options...
eldon Posted December 21, 2015 Share Posted December 21, 2015 I thought that you already had the alignment drawn in CAD as a polyline. If you are plotting a chainage and offset survey, I would still draw it manually, using distances rather than coordinates, especially as the offsets are not constant. Are the chainages at a constant interval? I wish you success in your quest for coordinates. Quote Link to comment Share on other sites More sharing options...
anindya Posted January 13, 2016 Author Share Posted January 13, 2016 can anyone please help me in that case because after getting the coordinates only i can paste it in autocad according to the drawing. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13, 2016 Share Posted January 13, 2016 You want a chainage and offset program that draws a series of points sq off a alignment. As already suggested, the method is pick a horizontal alignment, use the chainage point on the alignment, to draw a series of points as per your cross section values. Ch, +/- x, Rl The best advice is that this is commercially available with lots of other extras, like make a surface model and contours, road design etc Its just not a default in say CIV3D. I am working on something along this idea but no idea when it will be finished. In old fashioned surveying a level book reduction. Quote Link to comment Share on other sites More sharing options...
anindya Posted January 18, 2016 Author Share Posted January 18, 2016 ok sir i will wait.but pls help me in this case. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 19, 2016 Share Posted January 19, 2016 Ok here is a chainage offset and rl that will follow an alignment creating 3d points. Chainage,Offset,RL ; Read a csv file and create 3d points along a pline alignment ; by Alan H jan 2016 ;local defun for sq to pline (defun alg-ang (obj pnt) (- (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt)))(/ pi 2.0) ) ) ; thanks to Lee-mac for this defun (defun _csv->lst ( str / pos ) (if (setq pos (vl-string-position 44 str)) (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2)))) (list str) ) ) (defun drawpt (chain offsetd rl / pt pt2 ) (setq Pt (vlax-curve-getPointAtDist Obj chain)) (setq ang (alg-ang Obj Pt)) (setq pt2 (polar pt ang offsetd)) (setq pt2 (list (car pt2) (cadr pt2) rl)) ; add z (command "point" pt2) ) (defun chofrl ( / fname strval lst) (setq Obj (vlax-ename->vla-object (car (entsel "\nSELECT PLINE AS ALIGNMENT >>")))) ;(setq fname (open "c:\\acadtemp\\cross.csv" "r")) (setq fname (OPEN (getstring "\nEnter file name") "r")) (while (setq strval (read-line fname)) (setq lst (cons (_csv->lst strval) lst)) (setq chain (atof (nth 0 (nth 0 lst)))) (setq offsetd (atof (nth 1 (nth 0 lst)))) (setq rl (atof (nth 2 (nth 0 lst)))) (drawpt chain offsetd rl) (setq lst nil) (princ chain) ) (close fname) (princ) ) (chofrl) Quote Link to comment Share on other sites More sharing options...
anindya Posted January 19, 2016 Author Share Posted January 19, 2016 i am sending my drawing again please solve that.i have to show it in drawing(the location of each points)so if i get the result as type 2 in drawing i can do it easily. HHH1.dwg Quote Link to comment Share on other sites More sharing options...
anindya Posted January 26, 2016 Author Share Posted January 26, 2016 RESPECTED BIGAL SIR WHEN I HAVE TRIED TO USE THAT LISP I GOT A MESSAGE AFTER SELECTING THE ALIGNMENT,THE DRAWING THE CSV FILE I SAVED IN DESKTOP I AM SENDING TO U.THE MESSAGE I GOT I AM SHOWING TO U. SELECT PLINE AS ALIGNMENT >> Enter file nameC:\Users\Anindya\Desktop\Table1.csv point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0point Current point modes: PDMODE=0 PDSIZE=0.0000 Specify a point: Command: 0.0 HELP123456.dwg Table1.csv Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 27, 2016 Share Posted January 27, 2016 This will create pts ; by Alan H jan 2016 ;local defun for sq to pline (defun alg-ang (obj pnt) (- (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt)))(/ pi 2.0) ) ) (defun drawpt (chain offsetd rl / pt pt2 ) (setq Pt (vlax-curve-getPointAtDist Obj chain)) (setq ang (alg-ang Obj Pt)) (setq pt2 (polar pt ang offsetd)) (command "point" pt2) (princ pt2) (princ "\n") ) (defun chofrl ( ) (setq Obj (vlax-ename->vla-object (car (entsel "\nSELECT PLINE AS ALIGNMENT >>")))) (setq offsetd (getdist "\NEnter offset distance")) (while (/= chain nil) (setq chain (getreal "\nEnter Chainage press <Cr> to exit")) ;make this a loop of chainage steps (drawpt chain offsetd rl) (setq lst nil) (princ chain) ) (close fname) (princ) ) (chofrl) Quote Link to comment Share on other sites More sharing options...
anindya Posted January 29, 2016 Author Share Posted January 29, 2016 RESPECTED SIR :Bigal sir something is going wrong to me. i cannot understand that after selecting the alignment it is asking me to enter offset distance where the offsets are different as i showing on excel sheet.if it just ask me the name of excel sheet (say if i put it on desktop).and create the 3d points it will be fine.but it is not happening like that .pls help.i want to see the point on both side of alignment according to the mentioned distance in excel sheet of mentioned chainage. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 30, 2016 Share Posted January 30, 2016 Cadtutor is a free service so at some point the project gets big and the free time runs out. I have posted a how to method to get the point details it requires a loop to extract all the required values. If you want this and are prepared to pay I am sure someone can help. Otherwise can any one help ? Or you may need to start to learn lisp. There is everything you need to know here at Cadtutor its a case of joining it all together. Quote Link to comment Share on other sites More sharing options...
anindya Posted January 30, 2016 Author Share Posted January 30, 2016 ok i will wait.i got everything what i asked from here.i never felt that i can be upset from here.better i will wait may be anyone help me. Quote Link to comment Share on other sites More sharing options...
eldon Posted January 30, 2016 Share Posted January 30, 2016 Speaking practically, I hope that the example that you posted of an alignment was a fictional one, and not an actual real life situation. If it were to be a field example, I would question the ability of the surveyor to know where to survey on the cross sections without any ground marks. Quote Link to comment Share on other sites More sharing options...
anindya Posted February 1, 2016 Author Share Posted February 1, 2016 respected eldon sir i want to get the 3d points in the side of alignment from the datas i got from surveyor.the excel sheet i sent suppose i got from surveyor,now i want to see the offset points in the drawing. how to do it? Quote Link to comment Share on other sites More sharing options...
