eldon Posted February 1, 2016 Posted February 1, 2016 respected eldon sir i want to get the 3d points in the side of alignment from the datas i got from surveyor.the excel sheet i sent suppose i got from surveyor,now i want to see the offset points in the drawing. how to do it? I do not know the coordinates of the 3D points in my posted picture. I drew them relative to the alignment chainages, at the offsets in the excel sheet. I used the method that I suggested in post #6. You seem to be adamant that you need coordinates. Perhaps the surveyor's field method should be updated to enable faster processing. Quote
yathishkumar Posted February 1, 2016 Posted February 1, 2016 Could you try this link maybe it's help you. http://cadtips.cadalyst.com/2d-operations/find-station-and-offset thanks yathish kumar Quote
BIGAL Posted February 2, 2016 Posted February 2, 2016 Guys he wants what CIV3D and numerous other software does and that is to create cross sections from a surface model. Yes there is a formula for the height of a point on a 3dface. Press a button report 2 Chainage 0.000 X 269640.267 Y 5771459.122 Bearing 118°25'36" -5.150 12.5708 LRDCL 2.47% -0.450 12.4547 LLIP 13.33% -0.150 12.4147 LINV -375.00% -0.110 12.5647 LFACE 0.00% 0.000 12.5647 C.L. 0.00% 1.000 12.5647 RFPATH 2.67% 2.500 12.6047 RBACKPTH Quote
