Dj_T_Rex2002 Posted December 23, 2015 Author Posted December 23, 2015 Well this is how we have it set up. Each XREF has a unique name (e.g. XREF-OPT-BED5, another is XREF-STD-NOBED5). So if I want to work on the XREF-STD-NOBED5 I would like to hit a command and have those layers to freeze. We have all XREFs on layer zero because they don't want to create "more layers" (yeah right, like we don't have enough already). So if I try to use the LAYISO I click on the XREF and I can still see the others because of the way I have the fading set to 50 in order to make sure we don't overlay other stuff. And if I use LAYFRZ I have to click on every single item which then turns the layer off from that XREF but one at a time. I don't know if this makes sense. Quote
RobDraw Posted December 23, 2015 Posted December 23, 2015 Please explain why UNLOAD/RELOAD doesn't work for you. This gets the same result as freezing all the layers at once. Quote
