GypsyQueen Posted December 30, 2008 Share Posted December 30, 2008 Okies, I am pretty sure I know what happened here, and possibly even why, but I'm going to need help fixing it. One of my current projects is a 'cookie-cutter' project. The drafting for this project was done back in '05. I'm not fond of they style, but the company doesn't want to pour a lot of time into re-drafting (which is understandable). So to update some of the items to our current standards, I had to go through and update text and blocks to reflect the correct text size. I'm pretty sure these were copied over from an even earlier job as well and have been basically re-used several times. After I updated the text size and applied it, the "keynote" blocks went spastic on me and are either backwards or upside down. I would like very much not to have to replace all these blocks by hand (for the rest of the drawing which didn't get shown is pervaded with them as well). Any suggestions would be wonderful. Drawing attached for your perusal as well. MisbehavingBlocks.dwg Quote Link to comment Share on other sites More sharing options...
lpseifert Posted December 30, 2008 Share Posted December 30, 2008 Make sure the blocks are inserted at a scale of 1,1,1... I noticed some had an x-scale of -1. Qselect could select them all, use Properties to edit the scale. Quote Link to comment Share on other sites More sharing options...
GypsyQueen Posted December 30, 2008 Author Share Posted December 30, 2008 Make sure the blocks are inserted at a scale of 1,1,1... I noticed some had an x-scale of -1. Qselect could select them all, use Properties to edit the scale. That fixed it! Thank you kindly Ipseifert. And now I'm embarrassed that I didn't check that first. Quote Link to comment Share on other sites More sharing options...
