emmiec Posted December 31, 2015 Posted December 31, 2015 Hello! I really need some help on this issue. I am using Autocad 2007 and I have drawn this using the revolve command. See attachment. However when I want to export it to stl (to be printed using a 3D printer), I encountered this message 'No solids selected'. I am not sure how to proceed as I thought that the object created using revolve is already a solid one. Can anyone help? Thanks. Autocad.docx Quote
Cad64 Posted December 31, 2015 Posted December 31, 2015 The Revolve command can create solids or surfaces depending on what you're revolving: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-6FF936FD-99BA-432A-A43B-4573FD924AF3-htm.html Without having your CAD file to look at, I'm guessing that you revolved an open profile instead of a closed profile which produced a surface instead of a solid. Quote
emmiec Posted December 31, 2015 Author Posted December 31, 2015 Hi Cad64, Thank you so much! Yes, my mistake of not making it a closed profile. Now, the next problem when exporting to stl is that my drawing does not lie in the positive xyz octant. i've tried changing UCS and also doing a 3dorbit rotating it to make it lie in the positive xyz orbit but it is not working. Any tips/suggestions on this? Thank you:) Quote
Cad64 Posted December 31, 2015 Posted December 31, 2015 Changing the UCS and doing a 3dorbit does not change the location of your model. You need to physically move the object into the positive XYZ octant. Quote
