GPseudo Posted January 13, 2016 Posted January 13, 2016 Good day, When I try to draw in a sketch, a menu appears: http://imgur.com/a/cAw5N and often moves my mouse on it, interrupting what I was doing. Is there a way to disable it? Than you in advance! Quote
MarkFlayler Posted January 13, 2016 Posted January 13, 2016 You shouldn't disable it, as it is the selection filter that allows you to select objects obscured from view or difficult to select due to size. You can change how long it takes to pop up though. In your Application Options on your General Tab in the lower right is an area to control the wait time. You are seeing this perhaps too often because you are pausing on an object for too long. Quote
GPseudo Posted January 13, 2016 Author Posted January 13, 2016 Oh, I see, thank you. Indeed, I took my time to think things up. Quote
