hotrodz0321 Posted March 13, 2007 Posted March 13, 2007 How do i lock a viewport (make it unable to pan/zoom within the actual viewport) if the actual viewport is an object (circle)? I can lock other viewports using the property manager and just selecting "yes" under the lock viewport selection. But its a drawing created previously by another person and i cant lock the viewport...it just doesnt give me the option under the property manager like it does for typical viewports......any ideas? Quote
fuccaro Posted March 13, 2007 Posted March 13, 2007 When you select the boundary of that viewport you select two objects: the viewport itself and the polyline used to create the boundarie. On the top of the properties window it says something like "two objects selected". Click that text and you will have the possibility to choose what do you wish to have displayed. Choose the viewport and you will be able to access the Screen Locked propertie. Quote
hotrodz0321 Posted March 13, 2007 Author Posted March 13, 2007 When you select the boundary of that viewport you select two objects: the viewport itself and the polyline used to create the boundarie. On the top of the properties window it says something like "two objects selected". Click that text and you will have the possibility to choose what do you wish to have displayed. Choose the viewport and you will be able to access the Screen Locked propertie. THANKS...WORKED OUT GOOD Quote
Cymro Posted March 14, 2007 Posted March 14, 2007 I've got a custom button to freeze a viewport ^C^C-vports;lock;on;\; ideal to freeze a viewport quickly. Quote
asos2000 Posted August 26, 2008 Posted August 26, 2008 could that macro freeze al viewports in all layout? Quote
neekcotrack Posted August 26, 2008 Posted August 26, 2008 I've got a custom button to freeze a viewport ^C^C-vports;lock;on;\; ideal to freeze a viewport quickly. asos2000, It would have to be like this if you want to freeze all ^C^C-vports;lock;on;all;; Quote
