SAT / DWG export failure
I did manage to get it out as mesh.
Turning it into a solid seems just as hard in AutoCAD..
(mesh will do for now..)
Command: convtomesh
MESHSMOOTH
Select objects to convert: Specify opposite corner: 15 found
Command: surfsculpt
Mesh conversion set to: Smooth and optimized.
Select surfaces or solids to sculpt into a solid: Specify opposite corner: 15 found
Modeling Operation Error:
Cellular Topology structure is corrupt. Is topology okay?.
(what does Cellular Topology really mean? )
