Dinochrome
AutoCAD 2d to Inventor 3D workflow -with metric to inches thrown in....
Dinochrome
Does six months a Zombie thread make?
I found a different thread in a different sub-forum in which someone had asked a very similar, but somewhat different question. I thought I'd start my own thread rather than pollute his.
I am learning Inventor. I have been tasked with a sample job to draw. I have been going through an organized Tutorial Program my employer has footed the bill for.
I have also watched a lot of Neil Cross "TFI CAD" videos. He makes it easy to understand.
My task is to create production drawings of an assembly draw in 2D AutoCAD like a manufacturer might show to an Architect for approval. The output is to be 3D modeled in Inventor for production.
As I've been bringing my parts across, they are coming scaled down like they are drawn in millimeters. In AutoCAD when I check a dimension it shows inches and there aren't any strange setting in the DIMSTYLES that I can find. They are set to inches.
The donor AutoCAD file had INSUNITS set to 4. I switched it to 0. That didn't seem to change the behavior.
This is the Zombie thread: Insert Units Thread
I have not tried this: Editing Acaddoc.lsp
Any enlightenment would be appreciated.
As an aside, re: Neil Cross's work; here is an example of a well done tutorial on the steering wheel. I've used it like a wood saw on a steel pipe for years...
I posted a remark on it here a couple days ago. It's after hours and I'm doing a little self-improvement time and wanted to share this.
Edited by Dinochrome
un-gunking my grammar
Share this post
Link to post
Dinochrome
More enlightenment...
My drawing in question:
-DWGUNITS
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length : *Cancel*
Share this post
Link to post
Dinochrome
So, I soiled my sandbox copy....
Command:
-DWGUNITS
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length : 1
Drawing unit display formats:
1. Scientific
2. Decimal
3. Engineering
4. Architectural
5. Fractional
Linear display format :
Architectural linear display precision formats:
0. 1"
1. 1/2"
2. 1/4"
3. 1/8"
4. 1/16"
5. 1/32"
6. 1/64"
7. 1/128"
8. 1/256"
Linear display precision :
Scale objects from other drawings upon insert? [Yes/No] :
Match INSUNITS to drawing units? [Yes/No] :
** WARNING: you have changed the unit for this drawing database. **
** All new objects will be drawn according to the new unit, but **
** existing objects will not change size unless you specifically **
** ask to have automatic scaling occur. **
Scale objects in current drawing to reflect change in units? [Yes/No] :
Include objects in Paper Space? [Yes/No] :
Scaling the entire database...
Scaling AecDbObject(s)...
Scaling entities in Model Space...
Scaling entities in Paper Space...
Command: Z
ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : e
Command: *Cancel*
It didn't go well. My frame was 5", is now 3/16", and stuff is still inserting into Inventor at scale factor 0.03937.
Share this post
Link to post
Dinochrome
Trial and error! But next time I need it, I have it here!
Command: -DWGUNITS
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length : 1
1. Scientific
2. Decimal
3. Engineering
4. Architectural
5. Fractional
0. 1"
1. 1/2"
2. 1/4"
3. 1/8"
4. 1/16"
5. 1/32"
6. 1/64"
7. 1/128"
8. 1/256"
Scale objects in current drawing to reflect change in units? [Yes/No] : N
Command:
Share this post
Link to post
Dinochrome
My happy little pieces are cooperating and coming in pleasantly. I adjusted the AutoCAD side.
Share this post
Link to post
