sivapathasunderam Posted February 1, 2016 Share Posted February 1, 2016 Dear all; I have created a custom line type of Road marking 2m line & space 6m, again 2m line & space 6m as shown in image but it is not in scale at the beginning & end portion when i STRETCH as shown in the image it changes Why it happen? what is the ERROR? Pls. help I cannot able to reduce the cad file size below 1MB with the only line type object for attaching as reference Many thanks Siva Quote Link to comment Share on other sites More sharing options...
eldon Posted February 1, 2016 Share Posted February 1, 2016 When you create a linetype, AutoCAD guarantees that the endpoints of lines and arcs end with a dash. The pattern does not start with a fixed length. The whole line length is considered, and AutoCAD adjusts the first and last dashes to cater for the actual line length. You have no error. It is exactly how AutoCAD works. Quote Link to comment Share on other sites More sharing options...
sivapathasunderam Posted February 1, 2016 Author Share Posted February 1, 2016 Hi, thanks for your response. So there is no error Maybe future cad versions will have solution Kind regards Siva Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 1, 2016 Share Posted February 1, 2016 The description from @eldon applies when you use the "A" alignment code, but there is another code that generates linetypes differently. Neither one will do exactly what you want - unless the total length of your entity is exactly the same as the sum of the segment lengths. For example, if you have a linetype definition that says draw a 1 unit dash and a 1 unit gap, and repeat, how do you want it to appear on a line that is 6.7 units long? The A alignment code ensures that each interior dash and gap are exactly 1 unit long. The starting and ending segments are the ones who are modified. The S alignment code distributes the extra space among the dashes and gaps (with the unfortunate side effect of ending with a gap in this case) *A-Align-Code, __ __ __ __ __ __ __ __ __ A,1.0,-1.0 *S-Align-Code, __ __ __ __ __ __ __ __ __ S,1.0,-1.0 Quote Link to comment Share on other sites More sharing options...
sivapathasunderam Posted February 2, 2016 Author Share Posted February 2, 2016 The description from @eldon applies when you use the "A" alignment code, but there is another code that generates linetypes differently. Neither one will do exactly what you want - unless the total length of your entity is exactly the same as the sum of the segment lengths. For example, if you have a linetype definition that says draw a 1 unit dash and a 1 unit gap, and repeat, how do you want it to appear on a line that is 6.7 units long? The A alignment code ensures that each interior dash and gap are exactly 1 unit long. The starting and ending segments are the ones who are modified. The S alignment code distributes the extra space among the dashes and gaps (with the unfortunate side effect of ending with a gap in this case) Thanks so much McSwain, It a perfect idea & excellent knowledge. It seems to be great now Many thanks Siva Quote Link to comment Share on other sites More sharing options...
