adding a comma to numbers in autocad
newchurchr
 Share
Does anyone know the fastest way to add commas to numbers in autocad? I have alot of numbers in a drawing and i need to add commas to them all. Is there a lisp i could use to add them all at once?
i saved the text as an .lsp and loaded thru appload just like i always have and then i type rtoc to active the command nothing happens is there something i'm doing wrong.
(defun rtoc ( n p / d i l x )
   (setq d (getvar 'dimzin))
   (setvar 'dimzin 0)
   (setq l (vl-string->list (rtos n 2 p))
         x (cond ((cdr (member 46 (reverse l)))) ((reverse l)))
         i 0
   (setvar 'dimzin d)
   (vl-list->string
       (append
           (reverse
               (apply 'append
                   (mapcar
                      '(lambda ( a b )
                           (if (and (zerop (rem (setq i (1+ i)) 3)) b)
                               (list a 44)
                               (list a)
                       x (append (cdr x) '(nil))
           (member 46 l)
Edited by rkmcswain
Added CODE tags
You have to call it and pass two variables the number and precison (rtoc 123456789.09876 2)
(defun rtoc ( n p / d i l x ) defun rtoc, n & P are two variables to be supplied, d i l x are local variables used in the code, the / seperates local and global variables.
(setq num 1234567.23)
(rtoc num 2)
I'm not sure what else I can show you. Pass this function a real number (the one you want to add commas to), and an integer (the level of precision you want).
It's not a full working command that will allow you to select entities, etc.
Command: (rtoc 123456789.09876 2)
"123,456,789.10"
 Share
