Hello,
I am having a frustrating plot error (AutoCAD 2008 LT) that I haven't been able to pin down. The problem occurs when I am plotting to a physical plotter (HP designjet 500) AND when I attempt to plot to PDF. My best guess is that the system is low on memory (I got a "Windows low on virtual memory" popup today) but rebooting didn't help. Are there any work-arounds, if that's the case?
This is the error message I get:
Job: - Canceled
Job ID: 2
Sheet set name:
Date and time started: 1/2/2009 7:03:30 PM
Date and time completed: 1/2/2009 7:03:30 PM
UserID:
Profile ID: >
Total sheets: 0
Sheets plotted: 0
Number of errors: 0
Number of warnings: 0
Has anyone had (and been able to fix) this error before?
Thanks in advance,
-Joe and the Creative Life Designs crew
Is there an additional HP/GL2 card installed in the HP DJ500?
Has this happened before or is this the first time?
Did you do a warm reboot or a cold reboot?
We happen to have a HP DJ 500 and on ocassion experienced a problem similar to what you have described.
What happens if you send over a test plot from within Windows itself?
