sivapathasunderam Posted February 17, 2016 Posted February 17, 2016 (edited) Dear all; My end goal is to erase some of the parts from multiple drawings Command: Erase window specify first corner specify opposite corner enter Please correct the below "script" (command "Erase" "W" x,y x,y "") "First corner + opposite corner coordinates are same for many drawings" Thanks in advance for any help/advice Siva Edited February 17, 2016 by sivapathasunderam added one sentence Quote
ReMark Posted February 17, 2016 Posted February 17, 2016 If you want to do this using a script, to batch process a folder full of drawings, don't you need to also open, save and close each drawing as well? Quote
sivapathasunderam Posted February 17, 2016 Author Posted February 17, 2016 I am looking for the correct script file, then i will use Lee Mac's Script Writer Programme..... Quote
rkmcswain Posted February 17, 2016 Posted February 17, 2016 One way (the script part) ;; [color="red"]x y x y[/color] (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") Quote
BIGAL Posted February 18, 2016 Posted February 18, 2016 a simple example open dwg1 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Y open dwg2 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Y open dwg3 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Y Quote
sivapathasunderam Posted February 18, 2016 Author Posted February 18, 2016 ;; x y x y(command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") open dwg1 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Yopen dwg2 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Y open dwg3 (command "._erase" "_W" (list 5.1 11.2)(list 8.1 8.1) "") close Y Excellent! I really appreciate it. Thanks for the help! Quote
