IronHorse
Showcase 2015 - No textures
IronHorse
When I import a model from Inventor (2015) I start to select which parts I want
to assign to a specific material. But only one of them get with structure and the other not?? Why, I mark all at the same time. See attached Picture.
Share this post
Link to post
JD Mather
You can assign by part, by feature, by face and by body.
With imported parts you often need to right mouse button and Strip Overrides.
Share this post
Link to post
IronHorse
I do not get any choice to select by part feature etc. And no Strip overrides. However I remember these options from Inventor. But not Showcase 2015. I want to add new material within showcase. But loose texture on some of them. All model I import is assembly with parts. No multisolid.
Share this post
Link to post
JD Mather
Uhmm you never mentioned Showcase in your original problem description?
Share this post
Link to post
IronHorse
If I remember correct I posted this topic in Showcase Group. I have discussed with Autodesk and they are puzzled about this problem. They should look into this
issue.
Share this post
Link to post
Cad64
issue.
The Showcase section of the forum has absolutely nothing to do with the Showcase program. The Showcase section of the forum is just an area where people can post, or "Showcase", their most recent work. Basically it's an art gallery section.
We don't have a dedicated forum for the Showcase program, (I believe you're actually the first to post a question about it), but I have moved this question to the "Autodesk Software General" section: http://www.cadtutor.net/forum/forumdisplay.php?26-Autodesk-Software-General, since it apparently has nothing to do with Inventor.
I have also renamed your thread so that others will know what software you're using.
Share this post
Link to post
