DWG to XLS just simple
lemanhhung0302
 Share
Description
As you know, there are so many ways to copy AutoCAD® object(s) to Excel. In most cases, the result is image only (vector or bitmap). You cannot edit as much as you want.
DWG to XLS will solve this problem. The App will convert AutoCAD object(s) to Excel object(s), one by one. If you have a LINE in DWG, you will have one Line (SHAPE) in XLS.
AutoCAD Objects supported:
Curve (Line, Polyline, Arc, Circle, Spline, Ellipse...)
Dimension, Leader
Block
Hatch
Text, Mtext
Solid, Shape, Wipeout
Mor detail, please visit at https://apps.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Aautocadt oofficefre...
Demo:
http://www.tankhanh.com.vn - AutoLISP just simple!
I think you've made your point with the number of threads (one of which is ten years old) that you have managed to dredge up. Thank you for your diligence but thread necromancy is not encouraged here.
 Share
