mahmoudqaswal Posted March 28, 2016 Posted March 28, 2016 (edited) Hi i have a lisp it can match the text but the problem in this lisp is if i choose any think else text it show this message Incorrect Selection and end the order i need to change this plz to show this message no problem but not end the order i want to reaped the order again and thank you (defun c:mt (/ cEnt mEnt) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt)))) (redraw cEnt 4)) (princ "\n<!> Incorrect Selection <!>")) (princ)) (defun c:mt2 (/ cEnt mEnt sLst) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "TEXT,MTEXT,INSERT") (-4 . "NOT>")))) (mapcar '(lambda (x) (redraw x 2)) (setq sLst (mapcar 'cadr (ssnamex ss))))) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ)) (defun c:mt3 (/ cEnt ss) (vl-load-com) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget '((0 . "TEXT,MTEXT")))) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget x)) (entget x)))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ) Edited March 28, 2016 by SLW210 Changed PHP tags to Code Tags! Quote
rkmcswain Posted March 28, 2016 Posted March 28, 2016 Look at Example 1, here: http://lee-mac.com/selectif.html Quote
mahmoudqaswal Posted March 28, 2016 Author Posted March 28, 2016 thanks but i was try like that by using if and any condition but i was Fail and i am not good in lisp :) Quote
Lee Mac Posted March 28, 2016 Posted March 28, 2016 You may use my Copy/Swap Text program to match the content of selected annotation objects. Quote
