I'm working with a steam distribution company in a major downtown area. We have an overall map of our steam system in AutoCAD showing the two steam plants, the customers, valves and high pressure vs low pressure piping. I was wondering, is there a way to make an interactive version which would display which lines were active (highlighted flow maybe?). Also maybe the ability to highlight over a valve and switch it too closed and have the flow change? This may not even be feasible in AutoCAD but I'm just brainstorming here I guess, Any thoughts?
Take a look at a program called PCS 7 by Siemens.
Thanks! Ive been looking into that but it seems a tad complicated for my present situation. By complicated I mean I don't have the means to hook a majority the valves up to ethernet. Also, I cant seem to find a trial version : /
You would have to contact a Siemen's rep for a demo. Personally, I don't think you can do what you want with plain AutoCAD.
We use PCS 7 in our chemical plant for the process building operators to control batch processing. Tanks fill and empty. Valves open and close. Motors start and stop, etc., etc., etc.
