i have a LINE and i want to divide it into2 or more equal parts so that it will become many lines... so from 1 single line it will be cut into many.. is that doable in lisp??
example i have 1 line and i want to divide it into 5 lines... just like the break command, but i have to repeat my process everytime i break, i want to break a line into whatevet number i put so i would be more productive.
Yes, it is doable in lisp and fortunately for you someone has already gone ahead and done all the grunt work to accomplish the task.
You can thank Kent1Cooper for his Subdividelsp routine which can be found via this link. To execute the command load it into AutoCAD then at the command line type SD and just follow the command line prompt.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/break-line-not-divide/td-p/2572800/highlight/true/page/2
Look for the post with the 05-11-2011 date.
SPOT ON!
Exactly what i need!!! thank you so much!
All the thanks go to KentCooper....I just pointed you in the right direction. Glad to hear it fulfilled your needs.
You can actually do it and with PLINES, LINES, ARCS... Just convert them with PEDIT first into LWPOLYLINE and do segmentation with PLINETOOLS posted here :
http://www.cadtutor.net/forum/showthread.php?67924-Draw-polyline-along-with-2-or-more-adjacent-closed-polylines/page3&p=#25
After that all you have to do is explode LWPOLYLINES into LINES or ARCS...
HTH, M.R.
KentCooper's lisp routine does work on polylines, arcs and circles. It even works on splines but due to the nature of splines the result may not be what the user was looking for.
