CDM-ARCH
Using the line command to measure
CDM-ARCH
To find out the length of things in CAD I just use my line command and a distance box would appear above the line but no longer does. does anyone know how to get it back?
Share this post
Link to post
ReMark
You wouldn't happen to be referring to Dynamic Input would you? The toggle for it can be found at the bottom of your screen to the right. It's either On or Off.
Share this post
Link to post
CDM-ARCH
Perfect, that's exactly what I was looking for. I have no clue why it turned off on me. Thank you very much
Share this post
Link to post
SLW210
Dynamic Input, Sysvars are DYNMODE and DYNPROMPT you can also Right-Click the button and choose Settings.
Share this post
Link to post
BIGAL
DI DIST or from toolbar the dist icon, pick two pts and look at the info
Share this post
Link to post
paaray
Use the Measure Command to measure objects.
Share this post
Link to post
ReMark
One can also use the LIST command or check the Properties palette after clicking on a object.
Share this post
Link to post
rkent
Measure command is not for finding the length of objects.
OP should use either DIst command or MEAsuregeom command with DYNMODE on. Using the line command will work except when checking lengths in PaperSpace and the object is in ModelSpace.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
