I have two lisps to create double line ducts for HVAC. dline has the appropriate angles for transitions and allows you to see the outer lines while drawing. while tduct inserts text for the size of the duct(would be better if it was centered) and has a spot to put in the transition angle (usually 15 but nice to be able to choose if a different size is needed) any help combining them or even just what needs to be changed to one so it does it all would be great
  • 11 months later...
Hi there,
I loaded the program DLINE but it is not working. I am using autocad 2007. Any thoughts. I am searching for a good hvac duct drafting program.
thanks
-Ramesh
