waitsui Posted January 6, 2009 Posted January 6, 2009 ok so im trying to use autocad 2009, but my cursor is quite laggy, and normally its really smooth........i got this desktop like 4 months ago, so the hardware shouldn't b a problem...... I think i know what the problem is, just not sure how to fix it. I tried uninstalling the whole program and getting rid of everything autocad related to make sure everything is deleted. I tried installing again and a message saying my machine contains a 3D Device that is not certified. You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button. But the problem is, I tried checking for updates, but after it finish searching, it says Performance tuner failed to update. Please check your network connection and make sure you have write permission to the file...........So what am i suppose to do now? Here is a log from Autocad 2009: and btw I am using an Intel Quad Core Q6600. I know all my hardware is more than enough to handle cad. Performance Tuner Results Log Version: 17.2.0.1 Date of Last Tune: 1/5/2009 Machine Configuration --------------------- Processor Speed : 2.4 GHz RAM : 4094 MB 3D Device --------- Name : NVIDIA GeForce 9800 GTX/9800 GTX+ Manufacturer : NVIDIA Chip set : GeForce 9800 GTX/9800 GTX+ Memory : 2289 MB Driver : 7.15.0011.8048 Your machine contains a 3D Device that is not certified. As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website. You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button. Current application driver: direct3d9.hdi Current Effect Status: ---------------------- Enhanced 3D Performance: Available and on Smooth line display: Not available Gooch shader: Available and using hardware Per-pixel lighting: Available and on Full-shadow display: Available and on Texture compression: Available and off Available application drivers and effect support: ------------------------------------------------- Software driver Effect support: Enhanced 3D Performance: Not applicable Smooth line display: Not applicable Gooch shader: Software emulation only Per-pixel lighting: Not applicable Full-shadow display: Not applicable Texture compression: Not applicable Direct3D driver: Not Certified Effect support: Enhanced 3D Performance: Available Smooth line display: Not applicable Gooch shader: Available Per-pixel lighting: Available Full-shadow display: Available Texture compression: Available Enhanced 2D Performance: Available Quote
ReMark Posted January 6, 2009 Posted January 6, 2009 If the cursor was "laggy" maybe you should have looked into mouse related problems and their solutions before uninstalling then reinstalling AutoCAD. Don't you think that was a bit extreme? It's like you swapped engines in your car because you noticed a flat tire. You may have a problem with a setting in the Windows Registry. Do you have a Restore point you could go back to that predates the first installation of AutoCAD? Quote
rkent Posted January 6, 2009 Posted January 6, 2009 What operating system are you using? Do you have plain AutoCAD 2009 or a vertical? What other programs are running while working in AutoCAD? Antivirus, other CAD packages, etc.? I know when I have Inventor up as well as AutoCAD then AutoCAD is not worth trying to use, I see the same sticky cursor movement you are describing. I would doubt it is the graphics card, especially if this is only in 2D drawings. Quote
Jaelin Posted January 6, 2009 Posted January 6, 2009 3D Device --------- Name : NVIDIA GeForce 9800 GTX/9800 GTX+ Manufacturer : NVIDIA Chip set : GeForce 9800 GTX/9800 GTX+ Memory : 2289 MB Driver : 7.15.0011.8048 Your machine contains a 3D Device that is not certified. As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website. You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button. According to AutoCAD's website listing for graphics cards (http://usa.autodesk.com/adsk/servlet/hc?siteID=123112&id=6711853&linkID=9240618 ) the GeForce 9800 is not listed as having been tested for use with AutoCAD. I'm assuming this is probably just because it is a newer card and I would also assume that this card would work with AutoCAD but I guess there is that slight possibility that it's not supported for use with AutoCAD. This could be part of your issue but it still doesn't explain why your performance tuner is failing to update. Not sure what to say about that. As rkent asked, what is your O/S? This could be an issue as well because with your computer being new it could be a 64-bit processor with a 64-bit O/S and I have heard that there are issues with the 64-bit and AutoCAD though I can't confirm them because I don't run the 64-bit. Quote
ReMark Posted January 6, 2009 Posted January 6, 2009 Non-supported cards do not have AutoCAD specific drivers written for them. They will still work with AutoCAD because it is a Windows based program. Quote
waitsui Posted January 6, 2009 Author Posted January 6, 2009 I am currently using vista ultimate 64bit. A month ago everything work perfectly, but all of a sudden, it just started lagging on me. I tried system restore, but i was only given a few restore point that was too recent to go back to. I have plain autocad 2009, and I don't have anything running when working on cad. I am going to try uninstalling my current video drivers (from Control Panel...Programs). Then download the latest, WHQL certified version of the drivers for my system, hope this will helps. Quote
ReMark Posted January 6, 2009 Posted January 6, 2009 I'm just not seeing the problem between a laggy cursor and the video drivers as nothing really changed. Did you troubleshoot the input device you're using? Quote
waitsui Posted January 6, 2009 Author Posted January 6, 2009 Sighhh, still lags, I am running out of ideas. Would avoid using autocad 09, and getting an older version of Cad might solve my problem? And how do i troubleshoot the input device I am using? Quote
rkent Posted January 6, 2009 Posted January 6, 2009 I am currently using vista ultimate 64bit. A month ago everything work perfectly, but all of a sudden, it just started lagging on me. I tried system restore, but i was only given a few restore point that was too recent to go back to. I have plain autocad 2009, and I don't have anything running when working on cad. I am going to try uninstalling my current video drivers (from Control Panel...Programs). Then download the latest, WHQL certified version of the drivers for my system, hope this will helps. I think you can forget the video drivers, that is not going to be the issue. Lets not over look the obvious, are you using the new floating palette layer manager? If so, turn it off and leave it off. Also, turn off the visual effect settings in Options>Selection to see if that helps. See the advanced options while there for other settings. Do you have the display digital signature information checked in Options> Open and save? If so Uncheck it. Sorry if these suggestions are things you already knew about, but without more info we have to start from somewhere. If all else fails, check the tire pressure (I once had an error message on a beta product respond with "add water".) Quote
ReMark Posted January 6, 2009 Posted January 6, 2009 The beta product was a new bottle of Scotch. Quote
Arron Posted February 27, 2009 Posted February 27, 2009 Acer AMD Athlon Dual core 4850e (2.5 Ghz) 4 Gig Ram Vista Ultimate 64 Bit NVidia GeForce 9500gt AutoCAD 2009 64 Bit. Standard Wirless Intellimouse Explorer 2.0 Basic Logitech keyboard Any time the cursor (with NO command active and running osnaps off) passes over a dim starts to stall and lag until it moves past the dim. Actually selecting the dim causes more lag for at least 3-5 seconds. Durring that time any mouse movement of the mouse could cause it to move a grip This is true of ALL the systems at our office too. They have a variety of systems. One of the guys says he heard from somplace it was a conflict between windows and AutoCAD fighting over control of resources... Sounds like the same ACAD 12 issue when they first went onto Windows. Quote
rkent Posted February 27, 2009 Posted February 27, 2009 Maybe hardware acceleration is the issue, try the following: You can turn off hardware graphic acceleration fully or partially from the Control Panel: From the Start menu (Windows), choose Settings > Control Panel. In the Control Panel window, double-click the System icon. In the System Properties dialog box, select the Performance tab. On the Performance tab, choose the Graphics button. In the Application Performance section, move the slider all the way to the left to turn off video acceleration. If that works, then go back and move the slider one notch at a time until you see the problem, then move it back one. Quote
lroa Posted March 17, 2009 Posted March 17, 2009 have you tried going into the advanced settings of your graphics card? and under "Manage 3D settings" create program settings for just Autocad? Mine was a bit laggy at first then messed with the settings and it cleared all up. Quote
