malkasun
how to divide a polygon into 3 equal polygons (same area or we known area)?
I wanted to divide the polygon shown in the screenshot below into equal 3 polygons (with same area), but I couldn't figure out if these is some commands or workflow to perform this issue
is the "trial and error" is the only technique by which this issue can be done?
thank you in advance,
regards
malkasun
original?v=v2&px=-1
Share this post
Link to post
BIGAL
The parallel line is only one option a swing bearing from a point is another.
Answer to your question is yes iterate the area using a tolerance area=10.000001
Rectangs circles can be mathmatically worked out.
Search here there may be some code, the question has been asked before.
Share this post
Link to post
