OMEGA-ThundeR Posted May 11, 2016 Posted May 11, 2016 Hello, I'm trying to create a block through a lisp. The normal BLOCK command has an visual interface, so i use the -BLOCK command to use the commandline. However, when i create a block this way the objects that are in the block disappear, and the block is not in de insert list. Part of my lisp: (Defun C:VC ( / VP) (prompt "Select objects to blockerize: ") (setq VP(ssget)) (command "-block" "Block-temp" pause "P" "") It works as is, but with the problem of the objects i turn in to a block disappear. When i make a block the 'normal' way it all goes well... What am i doing wrong? (it's not working even if i don't use the lisp) Quote
marko_ribar Posted May 11, 2016 Posted May 11, 2016 Just guessing, but have you turned check box not to delete objects while creating block... Check BLOCK command - it should bring dialog box with this check button... Perhaps there is sysvar for this, investigate... Quote
Lee Mac Posted May 11, 2016 Posted May 11, 2016 The -BLOCK command will create a block definition with the given name containing the selected objects - you will then need to insert a reference of such block using the -INSERT command, or, if you wish to retain the original objects, you should copy the selection before supplying the objects to the -BLOCK command. Here are some alternatives: Objects to Block. Quote
