SuperCAD Posted May 13, 2016 Share Posted May 13, 2016 We have a user here who, despite numerous warnings, continues to keep his models in "hidden lines visible" display style and always saves them this way. Our experience has been that this is NOT the best way to save our models, and we want them to always be shaded with edges. I'd like to know if a macro can be written and coded to the save function so when he saves it will change the display style to shaded with edges BEFORE saving. It would be even better if we could have a message window pop up and warn him about saving parts and assemblies with hidden lines visible. Thank you in advance for any help you can offer. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 13, 2016 Share Posted May 13, 2016 Yes and no. No it cant be linked to the save button but you could create and place an api button to save and close while changing the display state. How is this an issue? I mean why is he(or she) against doing it the way the company wants? Quote Link to comment Share on other sites More sharing options...
Commandobill Posted May 13, 2016 Share Posted May 13, 2016 Yes and no. No it cant be linked to the save button but you could create and place an api button to save and close while changing the display state. How is this an issue? I mean why is he(or she) against doing it the way the company wants? You could set it to his save button if you updated it in his CUI... Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2016 Share Posted May 14, 2016 You could set it to his save button if you updated it in his CUI... bill, do you know of a way to re "link" the default buttons? I don't think its possible but i also can't say that i have ever tried. SuperCAD, i looked into the Solidworks Task Scheduler for this and you can make a macro and have it run in the Task Scheduler so that it can open his files at night, tweak the Shaded display and resave them. I have a few other things to do tonight but if i get a chance ill work up a simple macro. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 14, 2016 Share Posted May 14, 2016 (edited) Post removed solid works I need to look more closely Edited May 14, 2016 by BIGAL Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2016 Share Posted May 14, 2016 This is Dassalt Solidworks though not Autocad... Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2016 Share Posted May 14, 2016 SuperCAD, here is a simple macro you can copy/paste into an empty macro. This takes the current open/active part, sets the display to shaded edges, makes it an iso view, fits to screen, rebuilds, saves and closes. This should work for both parts and/or assemblies. If you want to play around with it comment out the save and close portions of the code by adding ' before it. You can change the view, display etc and then run the code. Option Explicit Sub main() Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swModView As SldWorks.ModelView Dim bRet As Boolean Dim swerror As Long Dim swwarnings As Long Set swApp = Application.SldWorks ' with SW Api you have to declare the application. When you do this right for all the variables you get the quickFill commands Set swModel = swApp.ActiveDoc ' this uses the swApp(Solidworks program) active document and sets it as swModel Set swModView = swModel.ActiveView ' this is in here so you can control the display state of the model. swModView.DisplayMode = swViewDisplayMode_ShadedWithEdges ' sets the display to ShadedWithEdges swModel.ShowNamedView2 "", swIsometricView 'empty string is for the VName, empty string uses ViewId which is the swIsometricView swModel.ViewZoomtofit2 ' fit model to the window swModel.ForceRebuild3 False ' the False is there mainly for assemblies. True rebuilds TopLevel assy only, False rebuilds the top level and sub assemblies. you can have it return a value if the rebuild ' was succesful or not by making a variable for example: Dim RebuildError As Long. then do RebuildError = swModel.ForceRebuild3 (False) this will pass a rebuild True ' or False into the RebuildError for you to do something with. swModel.Save3 swSaveAsOptions_e.swSaveAsOptions_Silent, swerror, swwarnings 'the Save3 is part of IModelDoc2 interface, the stuff in the are enumerations for Options, Errors and warnings. ' with things like this in SW API when you leave off the () you don't return a value, if you want to view or do something with a returned error you would need value = swModel.Save3 (Options, Errors, Warnings) ' you can find this info and what the enumerations are inside the Help menu under API Help topics. swApp.CloseDoc (swApp.ActiveDoc.GetPathName) 'closes the file End Sub Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2016 Share Posted May 14, 2016 i also want to note that you can do this with the Task Scheduler. I looked into a bit and you need to do a few custom things to handle it. The code will need a "path" and also some things like opening a document. Right now my code assumes you have a file open and it works with that. You will need a bit of code to work in a directory, open each file, change it, save and close it. There is a sample of this if you go to the SW help file http://help.solidworks.com/2016/English/SolidWorks/sldworks/t_Creating_a_SOLIDWORKS_Macro_Template.htm the sample code works in a directory, opens certain file types(drawings in their case) and saves them as dxf files. notice the $$$TASK_WORKING_DIR$$$. when you place the Token names $$$xxxx$$$ in the code it pops up in the task scheduler and lets you manually pick a directory for instance, or file. You could, with some clever programming i think, make it always go into his files at night and doing this. There are other ways to do this also. If you make a custom macro button using the Save icon and put it on his machine, just tell him when you save before you close to use this save button or something like that Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 14, 2016 Share Posted May 14, 2016 SuperCAD, here is a simple macro you can copy/paste into an empty macro."Simple"? Doesn't look simple to me. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 14, 2016 Share Posted May 14, 2016 I made the first 3 lessons on my API series free without registering. Might be enough for people who have seen code. https://www.solidbox.tv/course/solidworks-api-time-tracker/ Quote Link to comment Share on other sites More sharing options...
