How to receive camera target on the model viewport
IvanShubin
 Share
I create my app on the C# with using Autodesk.AutoCAD.Interop to interact with AutoCad. I try to receive camera direction:
var _app = (AcadApplication)Marshal.GetActiveObject("AutoCAD.Application");
var viewport = _app.ActiveDocument.ActiveViewport;
var dir = viewport.Direction;
but after rotaion of the model, I always receive same values of direction. If I use following code:
and activate viewport on the layout - after rotation of the model I receive difference correct direction.
How to receive correct camera direction on the model viewport?
but after rotaion of the model, I always receive same values of direction. . . . .
I found this in the AutoCAD ActiveX (the API in use via Interop) documentation:
No editing or view changes can be performed unless the viewport is active. To make a viewport active, use the ActiveViewport property on the Document object.
Once changes have been completed, the viewport must be reset as the active viewport for the changes to appear. To reset the active viewport, simply call the ActiveViewport property again with the updated Viewport object.
Thank you SEANT,
But I do not want to update of the ViewPort, I want receive actual value of the Direction. Every time, I create new instance of the ViewPort. But after namual change of the ViewPort Direction in the AutoCad, I alway receive same value of the Direction. If I restart the AutoCad - I receive the updated value of the Direction.
Any more ideas?
Can somebody check the following code:
Maybe I have problems with my AutoCAD.
 Share
