LISP code is abruptly stopping for invalid option keyword but I can't figure out why.
FIXED IT. CARRY ON!
LISP newbie here. I am writing the following code to automatically assign our office's layers to files we receive from a source outside the office. Many of these commands work but I cannot figure out why the code is abruptly stopping without finishing. It is stopping immediately after it makes the layer change from "TaxPropID" to "V-ANNO-PROP-OWNR-E". I have checked the spelling of these two layers and the spelling is correct. I have also checked the spelling on the next layer change from "Centerline" to "V-ANNO-ROAD-E" and it is correct as well. I could use some help determining where I messed up in the code.
Thanks
The Code:
(defun c:RICAIMS v0.1.0 ( / msg)
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Prop_LN")))
 			"_layer"
 			"V-Prop-Line-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Prop")))
 			"_layer"
 			"V-PROP-LINE-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "SmallDimension")))
 			"_layer"
 			"V-ANNO-DIMS-OTLN-N"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "AreaCAcre")))
 			"_layer"
 			"V-ANNO-SURV-N"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "TaxPropID")))
 			"_layer"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Centerline")))
 			"_layer"
 			"V-ANNO-ROAD-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Plat")))
 			"_layer"
 			"V-PROP-SECT-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "NFHL_X - 1 PCT FUTURE CONDITIO")))
 			"_layer"
 			"V-FLHA-100Y-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Stream")))
 			"_layer"
 			"V-CREK-CNTR-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "TreeOutline")))
 			"_layer"
 			"V-PLNT-LMTS-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "EarthDam")))
 			"_layer"
 			"V-POND-TOPB-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Fence")))
 			"_layer"
 			"V-FENCE-AIMS-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "GravelRoad")))
 			"_layer"
 			"V-ROAD-GRVL-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "PLSS")))
 			"_layer"
 			"V-PROP-SECT-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Thoroughfare")))
 			"_layer"
 			"V-ROAD-ASPH-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "CenterlineAnno")))
 			"_layer"
 			"V-ANNO-TEXT"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "NFHL_AE - FLOODWAY")))
 			"_layer"
 			"V-FLHA-100Y-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "UtilityPole")))
 			"_layer"
 			"V-POWR-POLE-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "PavedRoad")))
 			"_layer"
 			"V-ROAD-ASPH-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "Culvert")))
 			"_layer"
 			"V-STRM-PIPE-E"
(command
 		"_.chprop"
 			(ssget "_X" '((8 . "NFHL_AE")))
 			"_layer"
 			"V-FLHA-100Y-E"
The Command Output:
Command: RICAIMS
_.chprop
Select objects:   228 found
Select objects:
Enter property to change [Color/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]: _layer
Enter new layer name <Prop_LN>: V-Prop-Line-E
Command: _.chprop
Select objects:   24 found
Select objects:
Enter new layer name <Prop>: V-PROP-LINE-E
Command: _.chprop
Select objects:   38 found
Select objects:
Enter new layer name <SmallDimension>: V-ANNO-DIMS-OTLN-N
Command: _.chprop
Select objects:   5 found
Select objects:
Enter new layer name <TaxPropID>: V-ANNO-PROP-OWNR-E
Command: _.chprop
Select objects:   10 found
Select objects:
Enter new layer name <AreaCAcre>: V-ANNO-SURV-N
Command: _.chprop
Select objects:   3 found
Select objects:
Enter new layer name <Centerline>: V-ANNO-ROAD-E
Command: _.chprop
Select objects:   2 found
Select objects:
Enter new layer name <PLAT>: V-PROP-SECT-E
Command: _.chprop
Select objects:
Command: RICAIMS
Unknown command "RICAIMS".  Press F1 for help.
Command: _layer
Current layer:  "V-TOPO-MAJR-E"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: V-ANNO-PROP-OWNR-E
Invalid option keyword.
; error: Function cancelled
Edited by PinkSnail
Fixed it. I had a conflicting LISP and it wasn't executing the correct LISP. Newb mistakes, amiright?
IMO your code still needs some work. It can only run properly of every call to ssget returns a non-nil result. Most likely this is also the cause of your problem which actually occurs here:
Command: _.chprop
Select objects:  <------------- No selection set. Chprop command ends.
Command: RICAIMS <------------- Enter repeats the previous command.
Use something like:
(if (setq ss (ssget ...))
 (command ... ss "" ...)
Maybe something a bit more flexible :
[b][color=BLACK]([/color][/b]defun c:chlay [b][color=FUCHSIA]([/color][/b]/ ll ss[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq ll '[b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b][color=#2f4f4f]"1D-OLD"[/color] [color=#2f4f4f]"1D-NEW"[/color][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b][color=#2f4f4f]"2D-OLD"[/color] [color=#2f4f4f]"2D-NEW"[/color][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b][color=#2f4f4f]"3D-OLD"[/color] [color=#2f4f4f]"3D-NEW"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]foreach l ll
   [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]setq ss [b][color=GREEN]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=BLUE]([/color][/b]list [b][color=RED]([/color][/b]cons 0 [b][color=PURPLE]([/color][/b]car l[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
       [b][color=MAROON]([/color][/b]progn
         [b][color=GREEN]([/color][/b]if [b][color=BLUE]([/color][/b]not [b][color=RED]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] [b][color=PURPLE]([/color][/b]cadr l[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
             [b][color=BLUE]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color] [color=#2f4f4f]"_New"[/color] [b][color=RED]([/color][/b]cadr l[b][color=RED])[/color][/b] [color=#2f4f4f]""[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
         [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.CHPROP"[/color] ss [color=#2f4f4f]""[/color] [color=#2f4f4f]"_LA"[/color] [b][color=BLUE]([/color][/b]cadr l[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Manipulate the list 'll to your needs.
-David
